How to update the Relay G10/G10S firmware
Desplázate hacia abajo para ver las instrucciones en español.
Faites défiler la page vers le bas pour trouver des instructions en français.
Anweisungen auf Deutsch finden Sie weiter unten.
Per le istruzioni in Italiano scorrete verso il basso.
Updating Relay G10/G10S firmware from an internet-connected Mac or PC
Video Tutorial: G10/G10S firmware update instructions for Windows users
Video Tutorial: G10/G10S firmware update instructions for Mac users
First, download the latest version of the Line 6 Updater for Relay G10/G10S:
  • Go to www.Line6.com and click on "Support"
  • Scroll down and select "Downloads"
  • On the following page, set the three pulldown windows under "Free Software Downloads" to: [Relay G10 or Relay G10S], [Line 6 Updater], [your Mac or PC OS]
  • Click "GO"
  • The page will update with the latest Line 6 Updater version available. Click 'GET DOWNLOAD' to download the Updater program to your computer
  • You will be prompted to either log in to your Line 6 User account or to create a new account
  • Click on 'ACCEPT AND DOWNLOAD' and follow the on-screen instructions to save the Line 6 Updater installer file
  • After the file has been completely downloaded, double-click on the downloaded file and follow the instructions to install it to your computer
  • Mac Users: If you run into trouble with your Mac allowing you to install the download, please see this article.
Next, update your Relay G10/G10S Receiver and Transmitter
  • Insert the Transmitter all the way into the Receiver
  • Connect the receiver’s USB port to your computer with the USB cable that was included in the box, or use a similar Micro-USB cable (Note: some Micro-USB cables only charge devices and do not pass data. Try multiple cables of you cannot get a connection)
  • Run the Line 6 Updater program. Sign in to your Line 6 User Account.
  • Click on “Relay G10/G10S Receiver”
  • Click the “Update” button next to the latest firmware version. Follow the prompts to begin the update process. Important: Do not turn off or unplug your Relay receiver or computer during the update.
  • After the update is complete, repeat the process for the Transmitter by disconnecting and reconnecting the USB cable, then clicking “Continue” in the Updater
Please see this article if your computer does not detect your G10.
Cómo actualizar el firmware del Relay G10/G10S
Actualizar el firmware del Relay G10/G10S desde un Mac o PC conectado a Internet
Tutorial en vídeo: Instrucciones de actualización del firmware del G10/G10S para usuarios de Windows
Tutorial en vídeo: Instrucciones de actualización del firmware del G10/G10S para usuarios de Mac
En primer lugar, descarga la última versión del actualizador de Line 6 para Relay G10/G10S:
  • Visita www.Line6.com y haz clic en [Soporte].
  • Desplázate hacia abajo y selecciona “Downloads”.
  • En la siguiente página, verás tres ventanas desplegables en “Free Software Downloads”; selecciona “Relay G10 o Relay G10S”, “Line 6 Updater”, “el sistema operativo de tu Mac o PC”.
  • Haz clic en [GO].
  • La página se actualizará con la última versión de Line 6 Updater disponible. Haz clic en [GET DOWNLOAD] para descargar el programa del actualizador en tu ordenador.
  • Se te pedirá que inicies sesión en tu cuenta de usuario de Line 6 o bien que crees una nueva cuenta.
  • Haz clic en [ACCEPT AND DOWNLOAD] y sigue las instrucciones que aparecen en pantalla para guardar el archivo del instalador de Line 6 Updater.
  • Una vez el archivo se haya descargado por completo, haz doble clic en el archivo descargado y sigue las instrucciones para instalarlo en tu ordenador.
  • Usuarios de Mac: Si tienes problemas con tu Mac para instalar la descarga, por favor vea este artículo.
A continuación, actualiza tu receptor y transmisor Relay G10/G10S
  • Inserta totalmente el transmisor en el receptor
  • Conecta el puerto USB del receptor a tu ordenador con el cable USB incluido en la caja o bien utiliza un cable Micro-USB similar (Nota: algunos cables Micro-USB solo permiten cargar dispositivos y no transmiten datos. Prueba con varios cables si no consigues conectarte)
  • Ejecuta el programa Line 6 Updater. Inicia sesión en tu cuenta de usuario de Line 6.
  • Haz clic en [Relay G10/G10S Receiver].
  • Haz clic en el botón [Update] situado junto a la última versión del firmware. Sigue las instrucciones para empezar el proceso de actualización. Importante: No desactives ni desconectes tu receptor Relay ni el ordenador durante la actualización.
  • Una vez completada la actualización, repite el proceso para el transmisor desconectando y volviendo a conectar el cable USB; a continuación, haz clic en [Continue] en el Updater.
Consulte este artículo si su computadora no detecta su G10.
Mise à jour du système du Relay G10/G10S
Mise à jour du système du Relay G10/G10S avec un Mac ou PC connecté à internet
Tutoriel vidéo: Instructions pour la mise à jour du système du G10/G10S pour utilisateurs Windows
Tutoriel vidéo: Instructions pour la mise à jour du système du G10/G10S pour utilisateurs Mac
Téléchargez la version la plus récente de l’application Line 6 Updater pour Relay G10/G10S:
  • Rendez-vous sur www.Line6.com et cliquez sur [Assistance].
  • Faites défiler la page vers le bas et sélectionnez «Downloads».
  • A la page suivante, réglez les trois menus déroulants sous «Free Software Downloads» sur «Relay G10» ou «Relay G10S», «Line 6 Updater», «votre système Mac ou PC».
  • Cliquez sur [GO].
  • La page affiche la version la plus récente de Line 6 Updater. Cliquez sur [GET DOWNLOAD] pour télécharger l’application de mise à jour sur votre ordinateur.
  • Vous êtes invité(e) à vous connecter à votre compte utilisateur Line 6 gratuit ou à créer un compte.
  • Cliquez sur [ACCEPT AND DOWNLOAD] et suivez les instructions pour sauvegarder le fichier installeur de l’appli Line 6 Updater.
  • Une fois le fichier téléchargé, double-cliquez dessus et suivez les instructions pour l’installer sur votre ordinateur.
  • Utilisateurs Mac: Si votre Mac ne vous autorise pas à installer l’appli téléchargée, lisez cet article.
Mise à jour de votre récepteur et émetteur Relay G10/G10S
  • Insérez l’émetteur à fond dans le récepteur.
  • Reliez la prise USB du récepteur à l’ordinateur avec le câble USB fourni ou un câble micro-USB similaire. (Remarque: Certains câbles micro-USB se bornent à charger les dispositifs et ne transmettent pas de données. Essayez différents câbles si vous n’avez pas de connexion.)
  • Lancez l’application Line 6 Updater. Identifiez-vous avec votre compte utilisateur Line 6.
  • Cliquez sur [Relay G10/G10S Receiver].
  • Cliquez sur le bouton [Update] à côté de la version la plus récente du système. Suivez les instructions pour lancer la mise à jour. Important: N’éteignez pas et ne débranchez pas le récepteur Relay ou l’ordinateur durant la mise à jour.
  • Après la mise à jour, recommencez la procédure pour l’émetteur en débranchant et rebranchant le câble USB, puis cliquez sur [Continue] dans l’Updater.
 Veuillez consulter cet article si votre ordinateur ne détecte pas votre G10.
Aktualisieren der Relay G10/G10S-Firmware
Aktualisieren der Relay G10/G10S-Firmware mit einem Mac bzw. PC mit Internetzugang
Video-Tutorial: Anweisungen zum Aktualisieren der G10/G10S-Firmware (Windows)
Video-Tutorial: Anweisungen zum Aktualisieren der G10/G10S-Firmware (Mac)
Laden Sie sich die aktuelle “Line 6 Updater”-Version für den Relay G10/G10S herunter:
  • Surfen Sie zu www.Line6.com und klicken Sie auf [Support].
  • Scrollen Sie nach unten und wählen Sie “Downloads”.
  • Wählen Sie auf der nächsten Seite mit den drei Listenfenstern unter “Free Software Downloads” zunächst “Relay G10” oder “Relay G10S”, dann “Line 6 Updater” und Ihr Computer-Betriebssystem.
  • Klicken Sie auf [GO].
  • Auf der jetzt erscheinenden Seite wird die aktuelle “Line 6 Updater”-Version ganz oben angezeigt. Klicken Sie auf [GET DOWNLOAD], um sich das Updater-Programm herunterzuladen.
  • Loggen Sie sich in Ihr Line 6-Benutzerkonto ein (oder legen Sie sich ein Konto an).
  • Klicken Sie auf [ACCEPT AND DOWNLOAD] und befolgen Sie die Hinweise zum Sichern des “Line 6 Updater”-Installationsprogramms.
  • Nachdem die Datei komplett heruntergeladen wurde, doppelklicken Sie darauf und befolgen die Hinweise für die Installation auf Ihrem Computer.
  • Mac-Anwender: Wenn Sie die heruntergeladene Datei nicht auf Ihrem Mac installieren dürfen, siehe diesen Beitrag.
Aktualisieren des Relay G10/G10S-Empfängers und -Senders
  • Schieben Sie den Sender komplett in den Empfänger.
  • Verbinden Sie den USB-Port des Empfängers über das beiliegende (oder ein separat gekauftes) Micro-USB-Kabel mit dem Computer. (Anmerkung: Bestimmte Micro-USB-Kabel dienen nur zum Laden und übertragen keine Daten. Probieren Sie bei Bedarf mehrere Kabel aus.)
  • Starten Sie “Line 6 Updater”. Loggen Sie sich in Ihr Line 6-Benutzerkonto ein.
  • Klicken Sie auf [Relay G10/G10S Receiver].
  • Klicken Sie auf den [Update]-Button neben der aktuellen Firmware-Version. Befolgen Sie die Anweisungen, um die Aktualisierung zu starten. Wichtig: Schalten Sie den Relay-Empfänger bzw. Computer bei laufender Aktualisierung nicht aus und lösen Sie nie die Verbindung.
  • Nach geglückter Aktualisierung muss der Vorgang für den Sender wiederholt werden. Lösen Sie die USB-Verbindung kurz und klicken Sie im “Updater” auf [Continue].
Bitte lesen Sie diesen Artikel, wenn Ihr Computer Ihr G10 nicht erkennt.
Come aggiornare il firmware del Relay G10/G10S
Aggiornare il firmware del Relay G10/G10S da un Mac o PC collegato ad internet
Tutorial Video: Istruzioni per l’aggiornamento del firmware di G10/G10S per utenti Windows
Tutorial Video: Istruzioni per l’aggiornamento del firmware di G10/G10S per utenti Mac
Innanzitutto scaricate l’ultima versione dell’Updater Line 6 per Relay G10/G10S.
  • Andate su www.Line6.com e cliccate su [Support].
  • Scorrete in basso e selezionate “Downloads”.
  • Nella pagina seguente, in “Free Software Downloads” selezionate nei tre menu a discesa “Relay G10 o Relay G10S”, “Line 6 Updater” e “sistema operativo Mac o PC”.
  • Cliccate [GO].
  • La pagina si aggiornerà con l’ultima versione disponibile di Line 6 Updater. Cliccate [GET DOWNLOAD] per scaricare sul vostro computer il programma di aggiornamento (Updater).
  • Vi verrà chiesto di loggarvi con il vostro account Line 6 o di create un nuovo account.
  • Cliccate [ACCEPT AND DOWNLOAD] (Accetta e Scarica) e seguite le istruzioni sullo schermo per salvare il file dell’installer di Line 6 Updater.
  • Quando l’installer è stato completamente scaricato, per installarlo sul vostro computer fate doppio click sul file scaricato e seguite le istruzioni.
  • Utenti Mac: Se avete dei problemi perché il vostro Mac non vi permette di istallare, leggete questo articolo.
Poi, aggiornate il vostro Ricevitore e il Trasmettitore Relay G10/G10S.
  • Inserite completamente il Trasmettitore nel Ricevitore.
  • Collegate al vostro computer la porta USB del ricevitore con il cavo USB contenuto nella confezione o usate un cavo Micro-USB simile (Nota: alcuni cavi Micro-USB possono solo ricaricare i dispositivi e non passano i dati. Se non riuscite ad ottenere un collegamento provate più cavi)
  • Lanciate il programma Line 6 Updater. Eseguite il login al vostro Account Line 6.
  • Cliccate su [Relay G10/G10S Receiver].
  • Cliccate il pulsante [Update] vicino all’ultima versione del firmware. Per iniziare l’aggiornamento seguite le istruzioni. Importante: Durante l’aggiornamento non spegnete né scollegate il ricevitore Relay o il computer.
  • Terminato l’aggiornamento, ripetete il procedimento per il Trasmettitore scollegando e ricollegando il cavo USB, poi nell’Updater cliccate [Continue].
Consulta questo articolo se il tuo computer non rileva il tuo G10.
Edited by Line6Tony
